Old 08-03-2007, 10:13 PM   #1
locote
Default New to forum, I want a low 12sec potential machine!!
How r yall..
atm im driving a low 14sec honda civic..
im looking to upgrade to a car that has potential to run mid 12s...
my buget is 30k..
In mind atm i have Xr6t, Xr8 or LS1 powered commo..
Wich car do u guys think has the potential and keep me in my budget???
And what mods will i need??
Im also looking for auto box,
14.2@96mph Honda Civic...
I need real Horse Power
locote is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 10:18 PM   #2
old_mate
Smash the Boost
old_mate's Avatar
BF XR6T with ZF auto. Will run 14's stock. Spend some cash on edit and exhaust and CAI later and run 12's. 30k will get one with highish kays though i would imagine
Others will say buy a BA with the BTR but....nah
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 10:25 PM   #3
NA XR6
Whats a BTR
NA XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 10:34 PM   #4
Falchoon
Falchoon's Avatar
XR6T should be able to pick one up for low $20-25K. $5K worth of mods should see mid 12s ~300rwkw. 6 speed auto is preferable over 4 speed auto, stronger and nicer to drive.
Mods needed will be:
CAPA Flash box ~$1000,
injectors ~$500,
intercooler ~$500
fuel pump ~$200
CAI with K&N filter ~$200
hiflow 3.5" or 4" cat ~$500
valve springs ~$500
fitting and tuning $???? (most of the rest of your money).
Prices are all approximate, some may be cheaper, some may be dearer, depending on brand of components used.
XR8s are a bit more expensive than XR6T so you'll have less money for mods. So I would scratch that off the list.
You are probably in the wrong forum to find out much info about LS1s - try www.ls1.com.au
Falchoon is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 10:36 PM   #5
locote
thanks...
all this with 6psi or will i need to use a boost controller to run more??
Old 08-03-2007, 10:45 PM   #6
old_mate
Smash the Boost
old_mate's Avatar
BTR is the older 4 speed auto
1971 Fairmont Sedan
1974 SWB F100
Old 08-03-2007, 10:54 PM   #7
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
BA MK1 XR8...
$24-28,000
Full Exhaust
Oil Pump Gears (Safety item to stop stock ones from failing, no power gain)
Underdrives
BPR/G&D Cold Air Intake
Custom tuned Edit
Diff Gears
If manual a Clutch upgrade.
Mods Cost more than a XR6T to crack the 12's. ,About the same as a LS1 i would expect...
But you get a soundtrack the other two couldn't dream of, not to mention the Buldge...
FPV8U is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 10:59 PM   #8
locote
Hell yeah the sound is awsome I LOVE IT...
any know what or if the PD kit does anything???
Ive seen a few in mid 20s...
I think of a an xr8 as a cruiser with a bit of poke...
but im sure it can be made to go fast...
Ive seen a few doin 15s... thats why it scares me to buy one...
ive beaten a couple with my CIVIC wich is even scarier..
Old 08-03-2007, 11:05 PM   #9
locote
Manual or auto in the xr8???
Old 08-03-2007, 11:09 PM   #10
XR8-260
XR6T would be the one to get. Get the 6spd auto or manual. The BTR and T5 can't handle much torque. Btw, that's one fast honda civc you have there.
XR8-260 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 11:12 PM   #11
locote
not fast enough:(....
dont realy wanna spend more money on it...
And i also want bit more room, and A/C.
And dont forget torque
Old 08-03-2007, 11:15 PM   #12
Jasinex
Jasinex's Avatar
at willowbank last night a BA xr6T ute ran an 11.5 beside me down the quarter
jasinex
EA Series 2
now with fast parts added...
Stage 1: Buy car. with money.
Stage 2: Put in Wade Custom Cam, Crow Double Valve springs, High Flow Head, 3.23 LSD, 2.5" mandrell bent with Mercury muffler and custom made CAT, iridium plugs, nolothane bushes, Koni suspension, CAI.. NOW WITH MPFI....OHHH YEAHHH!!
Stage 3: More engine mods.. and a fresh new look... can't wait.. :eclipsee_ : :Reverend:
15.43 @ 89 mph - Willowbank Raceway 07/03/2007
Jasinex is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 11:17 PM   #13
locote
dam now thats waht im talking about!!!
Old 08-03-2007, 11:19 PM   #14
HLC
Audi S3
XR6t.
you simply cannot go faster for less.
Old 08-03-2007, 11:40 PM   #15
Ford_Boy
Ford_Boy's Avatar
The BA xr8 would be good for 14s stock. But If you really want to make a car go fast for cheap then your best bet is the xr6t. They are faster stock and cheaper to mod. The xr8 will cost abit extra and cost abit more for the same results but you will have a nicer sounding and better looking beast. get auto if your really keen on drag times
YOU 'RE A TOOL RICK YOU CHEATER.
ALL HAIL LOWNDES, THE TRUE CHAMPION!
Ford_Boy is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 11:42 PM   #16
XRated
Shoot.
XRated's Avatar
XR6T for getting into 12s easy and cheap.
LS1 for getting into 12s, probably not quite as cheap but has the awesome note of a V8.
XR8 if you want the bulge, the Ford badge and the note. Just be prepared to spend a bit more than the other two (or so I am led to believe).
20V Turbo
Old 11-03-2007, 01:48 PM   #17
pushrod4life
pushrod4life's Avatar
I don't think you can go wrong with any of those cars. With your budget I'd probably buy a VX SS (~$15-20k last I checked) or VY SV8/SS (early to mid $20ks) and either go exhaust, cam & heads and mafless tune; or get a CAPA blower kit (e.g. Powerdyne 5psi for 4k will get you around 290rwkw -- http://www.capa.com.au/kits_holden_ls1.htm)
But yeah check out ls1.com.au too. They know a shite-load more than me. =]
pushrod4life is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2007, 01:57 PM   #18
XR8putts
XR8putts's Avatar
XR6T with the new Auto box.
Nothing like it.
XR8putts is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2007, 02:27 PM   #19
I FluXx I
yep, go the T. 2k will see you in the 12's
BF MK1 RAPID F6 TORNADO, LEATHER, BREMBOS, FPV WHEEL, HARD COVER-304rwkw
Performance mods: SL's(front) and leveled at the back, Front 30mm whiteline sway bar, 4" dump, 4" cat, 3.5" exhaust split to Dual 2.5" with quad tips, Plazmaman stage 1 polished intercooler and piping kit, 60lb injectors, Walbro fuel pump, upgraded actuator, GFB BOV, K&N panel filter
Mods for show: 19" black Speedy Inferno rims, MTX 5x7's front and rear, 2x Kenwood 4ch amps, 3x Kenwood 10" subs, chrome fuse box cover
I FluXx I is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2007, 02:47 PM   #20
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
The XR6t gets my vote, it will be the cheapest to run a 12 and if you decide to up the ante down the track they are capable of huge power.
See here
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2007, 07:58 PM   #21
Lukeyson
Right out sideways
Lukeyson's Avatar
i love V8's, but for your budget, bang for ya buck would have to be a xr6 turbo !!!!
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 11:23 PM   #22
locote
What bout a xr8 with 3.9 diff gear and tune????
low 14s stock to low 13s???
Old 01-05-2007, 11:40 PM   #23
mustang70
i'd say the LS1 would get you there cheaper than XR6T if you're prepared to go for a VX with its slightly older styling, but to me the current XR range is starting to look dated anyway .
LS1 would sound a ton better than an XR6T too
of course you could also spend 4 grand on a nice old falcon and $26 000 on drive line and engine, now that'd get you there...
mustang70 is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 11:44 PM   #24
locote
lol...
Whole purpose of this exersice is to get a newer car....
Old 01-05-2007, 11:49 PM   #25
locote
3.23 rear ratio is real gay..
Im sure goin to 3.9 will make a huge difference in a stocker...
Old 01-05-2007, 11:49 PM   #26
XRchic
Hello
XRchic's Avatar
Mmmmmm Typhoon...
2008 FPV TERRITORY F6-X
Silhouette, window tint, roof racks, 3rd row seats, ROH Mantis 19s, black custom plates 'FPVF6X' and no stripes.
: Cobra :
XRchic is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 11:57 PM   #27
locote
ive read online the herrod 3.9 gears turn the xr8 into a totaly different car under acceleration???
Old 02-05-2007, 12:09 AM   #28
mrnsx
Crash test pilot
$20 stickers on ur civic and it should do 12's :P
Newest Addition
Holden Barina 2004
6L per 100k :
66kw :
Old Collection..
Falcon BA
Toyota Celica
Kawasaki zxr
Ford Festiva
Nissan 180sx
Daihatsu Feroza
mrnsx is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2007, 12:13 AM   #29
ThoR_
Holdens Fall Apart!
ThoR_'s Avatar
Buy a XD-XE 351 and work the motor big time. Wont be hard to get 12`s seeing a nice XD will cost you 6-7-8k...then you got the rest of your money to go into it.
AU2 XR8, Venom Red, 200kw, K&N Panel Filter, 2.5" Lukey Exhaust
ThoR_ is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2007, 12:15 AM   #30
b2tf
not here much anymore
b2tf's Avatar
but should he get a ute or a sedan?
2024 F150 XLT
